Discussion topic: Lost channel 402 Sky sports2
Message posted on 17 Dec 2023 01:24 PM
Saying no satellite signal on Sky sports 2. Everything else working fine.
Message posted on 17 Dec 2023 01:34 PM
Re: Lost channel 402 Sky sports2
@Mike100
If a “no satellite signal” message is displayed (even on just a couple of channels) firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. After that look at the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Your duplicate thread has been removed.
