10
This discussion topic has been answered Discussion topic: Lost UHD after box swap out.
This message was authored by: andyJR69
Hi.
My sky Q box suffered multiple hard drive issues so ive swapped it out for a new one. When i go into set up to set the quality to UHD it says my tv doesn't support UHD! It does and the old sky Q box managed it fine! Any ideas?
Re: Lost UHD after box swap out.
@andyJR69 wrote:
Yeah. When I sent the old box back, I left the HDMI cable in situ so that the new box could be plugged in using the same cable and port on the LG tv. That said, my box is 3-4m from the wall mounted TV which is why I use my own longer hdmi cable rather than the one supplied by sky. This all seemed to work fine with the old box!
I've ordered a new hdmi cable which should be delivered later today to see if that makes a difference.
Hi @andyJR69
Some Cables over 3 metres can have issues transmitting UHD/HDR.
Using an 8K 48 Mbps at 4 M here
This message was authored by: Padam_Padam
@andyJR69 wrote:
Hi.
Turn both the TV and the Q box off at the wall for a minute or two then power them both back on. This should hopefully re-engage the HDMI handshake between the two devices.
Avatar for andyJR69
Hardware is 32B108. The table in the link suggests this is not UHD?
Your box is UHD and HDR compatible.
Hi @andyJR69
32B1xx is the latest 2 TB box which is UHD/HDR
Avatar for andyJR69
Thanks all. Is it possible that I would get this issue if Sky removed UHD from my subscription/package for some reason?
This message was authored by: cuke
@andyJR69 are you using the same HDMI cable and into the same HDMI port on your tv. Also make sure that input signal plus is on for that port, if you have a samsung.
Avatar for andyJR69
Hi @andyJR69
Avatar for andyJR69
New 3m HDMI cable has fixed it! Thanks guys!!
