21
This discussion topic has been answered Discussion topic: Lost TV Channels following Switch to SkyQ
This message was authored by: Swindonviewer
I had my Sky+ box exchanged for SkyQ a few days ago, since when I no longer receive a signal to a dozen or so TV channels that I received with Sky+ continuously over the previous 8 years. These include Ch 103 ITV1 HD, Ch 105 CH5 HD, Ch 135 E4, Ch 203 ITV1 +1, Ch 313 Film4, Ch 411 TNT Sports 2, Ch 421 TNT Sports 4, Ch 503 BBC News HD, Ch 504 BBC Parliament HD and a few others.
I would have expected to be able to access all the same channels that I was previously receiving but the SKY TV engineer who replaced the box advised that, if I experienced any issues with lost signal, it would be a matter for my provider (See the Light).
Has anyone experienced similar issues who can advise, please?
Avatar for Swindonviewer
Level 2 icon
This message was authored by: Swindonviewer Answer
Re: Lost TV Channels following Switch to SkyQ
The OFNL engineer attended this morning. Tried various things without success but then replaced my 8-year old Quad GTU with the latest model, reset the settings on my TV set and that seems to have solved the problem. Now getting a signal to all of the 16 channels I lost after the SkyQ box was installed. Fingers crossed.
hi @Swindonviewer
Do you have your own dish or are you fed by a communal system ?
Level 2 icon
Communal. Wired into house (not dish).
Does that indicate you are on one of the very rare fibre-satellite (IRS) television installations?
hi @Swindonviewer  which is why the Engineer said you would need to refer to your provider.
SKy Q is slightly more sensitive to signal strength than SKY HD
Out of interest, did the engineer test all the transponders and  find issues at that point of installation ?
Level 2 icon
Hi nigea99, yes, he tested and said that I wasn't receiving a signal to a number of channels (before installing SkyQ). The majority were foreign language, children's TV channels etc that I would never want to view, so hadn't missed them and don't want to watch them now. I agreed to proceed with the switch to SkyQ on the basis that I wouldn't lose any of the channels I was currently receiving.
I spoke to See the Light today but his remote tests didn't solve the problem. Their engineer is coming tomorrow. Is there a way I can get a list of the Channels I should be able to receive for my package?
Although not a 1-1 match probably the easiest list I can point you at is the SKY Glass/Stream list - most of those listed as not available for Glass/Stream should be available to you I think also
https://www.sky.com/help/articles/tv-channel-list-sky-glass
Which presumably does indicate it's an IRS setup, because otherwise broadcast channel loss is not a network issue.
@nigea99 @Swindonviewer
Fibre IRS is satellite television, though, so channels should be as on Q.  The point is the dish doesn't have to be local.
Yes - I don't, personally, have a suitable link to a channel list via Satellite hence my  note & use of the Glass / Stream link
In theory you should 'receive' every channel in the EPG which doesn't require either a Sky subscription add-on (Sport/Cinema) or a subscription directly from an external provider (TNT etc).
I'd caution that there's very limited experience in this forum with STL set-ups though.
Level 2 icon
Thanks Timmy, I have the Sky Signature package (8 years plus) and Sky Sports, with TNT Sports via BT.
I'll see what the See the Light engineer has to say tomorow.
@Swindonviewer
Just a though: is the Q box plugged straight into a 'satellite' cable or to a wall port with multiple connections (such as radio and/or terrestrial television)?
Level 2 icon
It's connected to the wall socket marked "SAT 2". The "SAT 1" port has nothing connected to it.
Level 2 icon
Sorry, I should have added that the socket also has a "FM/DAB" port (which has nothing plugged into it) and another aerial socket, which has my VCR plugged into it.
