Discussion topic: Loss of satellite signal below 4 degrees Celsius
Message posted on 16 Jan 2024 02:16 PM
Why is that whenever the outside temperature falls below 4 degrees Celsius I start losing Channels (either blue screen with with Channel currently affected etc, or freezing after a few seconds and then disappearing), with only France 24 HD remaining and sometimes BBC Parliament?
I understand that some SP Channels as opposed to HD Channels will continue to be watchable, but how do you find these easily?
Message posted on 16 Jan 2024 02:17 PM
Re: Loss of satellite signal below 4 degrees Celsius
How long is it since you had Sky Q installed? Could be a failing LNB if it was more than say 5 years ago.
Message posted on 17 Jan 2024 11:57 PM
I have only had the Q box for over a year. The dish is older, but the LNB has several outputs, and is relatively new
Message posted on 18 Jan 2024 10:20 AM
@Fourie It could be that your dish is right on the limit of alignment with the satellite, and when the supporting metal frame contracts in the cold, this pulls the dish out of alignement. You will need to get Sky to come out and do an alignement check / realign the dish.
Message posted on 27 Nov 2024 05:07 PM
More than 5 years I think
Message posted on 28 Nov 2024 12:01 PM
@DennisMar wrote:More than 5 years I think
Sorry, what is "more than 5 years"???
