2
This discussion topic has been answered Discussion topic: Loss of picture and blue screen.
This message was authored by: Chris+Jce
Since Saturday, my main Sq Q box has been losing all signal, showing a blue screen and the fan running. All the mini boxes show no satalite signal, and then the blue screen.
I updated the main box software, did not help. I have done a hard drive reset, briefly helped until tonight and now back to blue screen and fan running. Any ideas on what to try now, or is it a new main box?
The sky box is connected directly to a Sky router, and is showing functioning correctly on the Sky App.
Any ideas would be welcome.
Avatar for Chris+Jce
This message was authored by: Chris+Jce Answer
Re: Loss of picture and blue screen.
Thank you for the information. It is indeed a new box required, which should arrive today. I'll double check the power cord before I let the courier go.
Hi @Chris+Jce
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
