Discussion topic: Loss of channels
Message posted on 10 Jan 2026 03:44 PM
Loss of channels
I have lost several channels, I am told to upgrade,the only advice is to add sky sports and kids which we don't want.Tried un plugging box, still the same.
Message posted on 10 Jan 2026 04:00 PM
Re: Loss of channels
@RitaRM what channels have you lost ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 11 Jan 2026 10:20 AM
Sky news, dicovery, can't record anything on the channels we have, all our recordings have gone.
Message posted on 11 Jan 2026 12:35 PM
@RitaRM if you have already tried rebooting your main Q box ie
then
You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
