Discussion topic: Losing signal since May sky issue
Message posted on 13 Jun 2025 11:33 PM
Since the downtime issue in May that affected all sky customers my Sky Q box is losing signal every few minutes.
I have done all the power/reset options and still the same problem.
my signal and quality strength are 50/90.
It's happening so often that I have to watch iplayer etc to watch a program.
Except for recording which is also affected i might as well not have a Sky Q box.
Message posted on 14 Jun 2025 04:51 AM
Re: Losing signal since May sky issue
Any error message displayed at the top of the screen?
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Message posted on 14 Jun 2025 06:19 AM
@thedevilsown wrote:Since the downtime issue in May that affected all sky customers my Sky Q box is losing signal every few minutes.
Sounds like a slight dish misalignment . Signal strength/quality on Q Boxes is a bit of a red herring as it only checks one transponder, not the transponder you are currently viewing like Sky+ HD Boxes.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 14 Jun 2025 03:24 PM
Just get the no satellite signal from the box
Message posted on 14 Jun 2025 03:26 PM
Then follow the earlier advice to arrange a Sky engineer.
