Discussion topic: Losing connection with Sky Q box MR209 whenever my son goes on his Playstation - I have the mini box
This message was authored by: 3lc
I am unable to watch Sky when my son goes on his Playstation - connected to the TV with the Sky Q box.
My TV is connected to the mini box & loses connectivity.
At other times the connectivity appears to stop & start, making it impossible to watch a program. Sky Q has only recently been installed because Sky Go would no longer work so I'm now in the same position I was in before Sky Q was installed
Re: Losing connection with Sky Q box MR209 whenever my son goes on his Playstation - I have the mini
Hi @3lc
Reboot the mini as above.
This message was authored by: barbnstu
yes but im having same issue everyday , how many times do we have to keep reconnecting till problem at skys end is fixed.
