Discussion topic: Live TV not working after installing broadband
Message posted on 04 Jul 2024 09:06 PM
Message posted on 04 Jul 2024 09:16 PM - last edited: 04 Jul 2024 09:19 PM
Re: Live TV not working after installing broadband
Hi @sengupta
I'm sure you are aware that live TV comes from your Satellite and not from the internet.
If you have internet connection issues then first reset your broadband router.
Message posted on 05 Jul 2024 08:32 AM
It is Sky Q you have and not Sky Stream or Glass?
If it is Q then check the connections at the back of the box if it was disturbed in order to plug a cable in from the router.
