Discussion topic: Linking Sky Q remote to LG OLED 42C 44LA tv
This message was authored by: GregTaylor
Is my Sky Q remote compatible with an LG OLED 42C 44LA tv?
What codes are need to configure the link
Re: Linking Sky Q remote to LG OLED 42C 44LA tv
Hi @GregTaylor
No codes for Q remotes. They work on Brand and model to pair to Television .
Should be no issue with LG.
Avatar for GregTaylor
Hi,
Sorry, should have replied sooner.
Thanks, all is good now
