Discussion topic: Last week i suddenly stopped being able to get ITV2, Channel 5, Really and a few others. How to fix
This message was authored by: Elaine1928
Does anyone know how to fix this without the painful experience of ringing Sky??
Anyone else had this?
Re: Last week i suddenly stopped being able to get ITV2, Channel 5, Really and a few others. How to
@Elaine1928
What error message are you seeing if any?
Avatar for Elaine1928
This channel is currently affected by a problem with your satellite signal.
But makes no sense as everything else is working
Hi @Elaine1928
Afraid it looks like you need to contact Sky for an Engineer to check your dish.
Alternatively you could work through the following link and it should give you the option to book an engineer.
But how can the dish be faulty if only a few channels don't work and the rest are fine??
@Elaine1928
Sounds like it might be slightly out of alignment.
Hi @Elaine1928
Depending on the severity of Dish misalignment it's possible it will start by affecting just a few channels.
The link I posted will give you the option to book an engineer if you work through it.
