6
This discussion topic has been answered Discussion topic: Lack of signal so key channels not being received
This message was authored by: shinyf1
Over the last few weeks several channels have dropped out with this on screen message
"The channel is currently affected by a problem wiht your satellite signal. For help, press (?)....."
Can't seem to contact Sky about it
Affected channels are:
105 - Channel 5 HD
107 - Sky Witness HD
108 - Sky Atlantic HD
111 - U&Dave HD
113 - Sky Max HD
114 - Sky Comedy HD
118 - ITV 2HD
119 - ITV 3 HD
121 - Sky Documentaries HD
122 - Sky Crime HD
123 - Sky HIstory HD
125 - Discovery HD
128 - 5 Star
135 - E4 HD
136 - More4 HD
402 - Sky Sports PL HD
404 - Sky Sports Cricket HD
407 - Sky Sports Tennis HD
All TNT Sports channels
All Premier Sport channels
Plus lots of channels we don't ever watch
This message was authored by: nigea99 Answer
Re: Lack of signal so key channels not being received
hi @shinyf1
I can't remember all the steps in that link so not sure if this one is mentioned
With so many channels & from a quick look at the frequencies it makes me think that one of the cables is damaged or not properly connected. The 2 different cables carry the different Polarity signals
The SKY Q signal strength indicator can be quite misleading as it does not show the status of the channel you are watching but the status of  a test transponder which is on a  vertical transponder - most of the channels I looked at from your list are Horizontally polarised
Thus look at both connectors and if possible check that none of the fine strands of the outer sheath braiding are in contact with the central core wire - also check that the central core wire is just slightly protruding from the connector. Then reseat the connectors if all is OK
If you still have problems, as I mention the link I provided should lead you to a link to book an engineer
@shinyf1
Please see the following page that covers a few problems - if you follow the link through and still have problems then you should find a link to book an engineer if you have your own dish
If you have a communal system you may have to contact your building management to deal with the technicians responsible for the system
Avatar for shinyf1
Own dish, signal strength 70 and signal quality 90, plus perfect weather. Just done a software update on the box and made no difference. Very frustrating
@shinyf1 wrote:
Very frustrating
But clearly a local issue, because no-one else is reporting anything similar.
hi @shinyf1
@shinyf1  I agree with @nigea99  the channels you mention are all Horizontally Polarised which would suggets a cable or LNB issue
Avatar for shinyf1
Sorted - rechecked the connectors and all back to normal.
thank you
