Discussion topic: LIT Fibre Sky Q box disconnects
This message was authored by: CJMylchreest
Hi all,
We had LIT fibre 500 installed last week and ever since, our Q box, but nothing else, continually disconnects and needs resetting. This is despite the connection being 20 times faster than our previous Sky broadband.
We have it connected through a TP Link deco mesh.
Any help with this would be appreciated.
Thanks.
Re: LIT Fibre Sky Q box disconnects
Q won't connect to many mesh systems via WiFi - it will connect then disconnect in less than a minute.
Can you connect via Ethernet?
try ethernet to a deco to piggyback the mesh.
do you have minis?
Avatar for CJMylchreest
Hi. I have tried connecting via Ethernet to the deco, but it won't find the connection for some reason.
Why on earth doesn't it connect to mesh systems?
No minis, no.
I will
try Ethernet again, but that seems so old fashioned.
Thanks.
I bet the latest high powered cloud servers don't use wifi 😉 Ethernet isn't old fashioned.
When you plugged into the deco, did you do a full network reset and start again configuring it to use ethernet?
No. Just tried finding a wired connection in the sky q box setup. It wouldn't find anything.
I'll try that, thanks.
It's all a bit weird. It didn't work for me first time (BT Wholehome) but did when I lost my marbles and resorted to trying again about 6 months later.
This message was authored by: J+Sidders
Hi,
Did you manage to get this to work.
Lit Fibre was installed for myself and a lot of others in my areas at the end of last year.
Internet works fine on all devices but the sky q box keeps disconnecting and we have to reset the WiFi and re-enter the password etc.
I just tried to reconnect it and now I have a a message saying no networks found!
Sky came and installed a new sky q box last week and it's made very little difference!
Any help or advice would be great, Sky did not seem to have a clue when I spoke to them...
J
Join the club
https://helpforum.sky.com/t5/Sky-Q/Sky-Q-box-regulary-loses-internet-connection/td-p/4325268
Gaz1's solution towards the end using a cheap wifi extender seems solid.
