This discussion topic has been answered Discussion topic: LG to sky box no signal
Message posted on 12 Nov 2025 06:56 AM
Sometimes when I switch on my LG tv and my sky box the tv says no signal so it's not seeing the hdmi1 connection.
I power everything down and then restart and it works. It is happening more often now not just occasionally.
Message posted on 12 Nov 2025 08:31 AM - last edited: 12 Nov 2025 08:31 AM
Hi @Hogstar57 When your Tv and SKYQ box are both on standby, turning the SKYQ box on first should turn the TV on sconds later.
Alternatively turn your TV on followed by the SKY box.
Message posted on 12 Nov 2025 10:24 AM
Re: LG to sky box no signal
Hi @Hogstar57
Try completely removing and the refitting the HDMI cable between the Q box and TV.
Failing this try a different HDMI cable if you have one.
Message posted on 12 Nov 2025 10:33 AM - last edited: 12 Nov 2025 10:34 AM
@Hogstar57 wrote:Sometimes when I switch on my LG tv and my sky box the tv says no signal so it's not seeing the hdmi1 connection.
No further advice than what is already given, but just to say, this has always been the case with Sky Q and LG equipment sadly.
There doesn't seem to be a permanent fix other than blocking pins by buying a 'HDMI CEC Less Adapter', which means you turn everything on and off manually.
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | SONOS Beam 2 | Apple TV 4K | EE Full Works FTTC
Message posted on 12 Nov 2025 04:20 PM
Are you long pressing the SkyQ remote's on/off button or just a quick press? A long press turns our LG TV on as well as the Q box. Your problem sounds like it's turning the TV on but not the box.
I don’t work for Sky.
If I have helped then please leave a like.
