Discussion topic: LG TV which has stopped recognising the Sky Q box
Re: LG TV which has stopped recognising the Sky Q box
@MarkA30 wrote:
I used mE182 and switched off HDMI control via Settings - Start up and Stand - HDMI Control off.
However, there is a much simpler solution to the No Signal message after you have closed Sky.
Hold the Sky Remote powerbutton for about 3 seconds!
This sounds like you're just turning the TV off?
This message was authored by: MarkA30
Yes true. I tried to edit.
But we couldn't switch our TV off without thr signal message, which is what got me here. But not thr same issue as others are facing I admit.
This message was authored by: hrai
Probably done but as it sounds like that (due to wall mounting?) you can't access the socket have tried connecting another device to the tv using the same cable & hdmi socket - games console, dvd player, laptop, pc etc. - to eliminate them as a source of the error?
