Discussion topic: Keeps saying technical issue when trying to watch red button. Screen pauses when trying to rewind?
Message posted on 25 Oct 2023 08:03 PM
Message posted on 25 Oct 2023 08:18 PM
Re: Keeps saying technical issue when trying to watch red button. Screen pauses when trying to rewin
hi @Angusj
As regards Red Button use check if you are set to record 6
in Home - Settings - Setup - Preferences?
If you are try changing to 5.
Then reboot your Q box.
As regards the rewind what are you trying to rewind?
Message posted on 25 Oct 2023 08:26 PM
Thanks, am currently trying this, my record number is already 5, will this make a difference?
And just trying to rewind any live programme, will freeze the programme
Message posted on 25 Oct 2023 08:28 PM
it worked. thank you
Message posted on 25 Oct 2023 08:31 PM
Hi @Angusj
Best to leave at 5 as if set to 6 you lose Split screen use.
To rewind most live content you need to have been watching for at least the amount of time that you want to rewind.
