Discussion topic: Keep receiving an error : Mr001 code on sky mini box even after new box was delivered.
Message posted on 09 Apr 2024 07:05 AM
We keep reviewing an error MR001 code on our sky mini box. Our booster and the main sky box are all connected and working. It had been working for the last year and suddenly stopped. We have replaced the sky mini box already and still not working.
Message posted on 09 Apr 2024 08:07 AM
Re: Keep receiving an error : Mr001 code on sky mini box even after new box was delivered.
Hi @Alexkotz93 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, followed by any Mini boxes?
Message posted on 09 Apr 2024 12:29 PM
I have tried this a few times and still nothing.
Message posted on 09 Apr 2024 12:39 PM
Hi @Alexkotz93
Try a Network Reset on the mini.
If you are on Sky Broadband and the Router or Sky Q booster is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the rest button.
