Discussion topic: Keep getting a message there’s an issue with the connection with this sky q mini box and the Q box
Message posted on 17 Apr 2024 09:43 AM
Hi I keep getting a message that's a connection issue between my Sky mini box and my Sky Q box
Message posted on 17 Apr 2024 09:48 AM
Re: Keep getting a message there’s an issue with the connection with this sky q mini box and the Q b
Hi @Delskie
Reboot the mini as above.
