Discussion topic: Just upgraded to hub 5 on virginmedia to increase internet speed now sky won’t stay connected
Message posted on 22 Jul 2023 08:27 AM
Just upgraded to Hub 5 on Virgin media (wifi6) and now the Sky Q boxes won't stay connected . I keep having to reset the network connection and it will stay connected for about 3 minutes and then loses connection! Sorry if this has already been discussed but I couldn't find it anywhere
Message posted on 22 Jul 2023 08:51 AM
Re: Just upgraded to hub 5 on virginmedia to increase internet speed now sky won’t stay connected
Hi @Fergus47 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
Message posted on 22 Jul 2023 09:08 AM
Hi @Quoman7 thank you, I tried that first but 😤unfortunately!
Message posted on 22 Jul 2023 09:11 AM
Sounds like the Virgin router is steering the signal to 5GHz (which will drop out). The Q box will only stay connected to a 2.4GHz connection.
Message posted on 22 Jul 2023 09:30 AM
Hi @PandJ2020 thank you, I have done this but it is now very slow, why do they have the option of 5ghz if it isn't useable?
Message posted on 01 Dec 2024 02:46 PM
Connect them wired from sky q to mini box and leave for 30 min. Then pull data cable out and the WiFi should hold as that's what I have to do when connectivity problem comes up
