Discussion topic: Ive lost my sky q remote how can i change chanels
This message was authored by: Trafford55
I've lost my skyq remote how can I change channels until my new one arrives
This message was authored by: bob1234
Re: Ive lost my sky q remote how can i change chanels
@Trafford55Have you tried this.
"Press the Q button on the front of your Sky Q box and after a few seconds a paired Sky Q touch/Sky Q remote with Voice Control will beep for 30 seconds."
If you can't find it there are several apps that claim can be downloaded to mobile phones to control Q, I have no idea how good any of them are.
This message was authored by: mappion
Hi @Trafford55
As a tempporary measure if you have an Android phone I have an app called 'Sky Q Free Remote' that does work.
As @bob1234 has said there are others and I am sure there are others for iphones as well.
None of these are anyway near as good as a proper remote though.
This message was authored by: best+of+the+best
Hi @Trafford55
Like @bob1234 and @mappion have said
there are apps available that will operate your Sky Q box.
But the most obvious one is actually your remote for your tv I have an LG Magic Remote  that operates my Sky Q box and voice control is available also.
