5
This discussion topic has been answered Discussion topic: Ive got a replacement sky Q box but cannot get past setting page on restart and remote not pairing
This message was authored by: alan+mcc
Remote not pairing so cannot access settings
Re: Ive got a replacement sky Q box but cannot get past setting page on restart and remote not pairi
@alan+mcc wrote:
Thanks, tried this but still not getting past settings page
Hi @alan+mcc
Did you try just the 7 & 9 without further pairing?
7 & 9 sets the remote to infrared mode which will control all Q boxes without further pairing.
The remote must be pointed directly to the Q box when in infrared.
Hi @alan+mcc
Reset your Q remote by pressing  and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes.   However the remote must be pointed directly at the Q box.
Switch your  box back on and you then you should be able to access the settings.
Once you get the Q box working make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
May I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Avatar for alan+mcc
Hi @alan+mcc Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
Hi @alan+mcc
