Discussion topic: Ive cancelled sky and i have to return the sky box . I also want the sky dish removing as it i
This message was authored by: Matt+Bradbury
I have cancelled sky and have to return the sky box as it is their  property . I also want to have the sky dish removed and returned as it is sky property . Will an engineer come out to remove from my property
thanks matt
Re: Ive cancelled sky and i have to return the sky box . I also want the sky dish removing as
thanks matt
hi @Matt+Bradbury
The dish & cabling are your property & you can do with it what you wish but SKY won't remove it for you..
SKY only require the SKY Q boxes, remotes, power cables & HDMI cables returning
You could get any suitable handyman to remove the dish & coax cables if you want them removing.
 From the contract, "The Sky Dish is not loaned to you and becomes your property to keep on installation".
