7
This discussion topic has been answered Discussion topic: Itv and channel 5 satellite signal down
This message was authored by: Steve+quinnell
All itv 1 and 2 is currently showing satellite signal problem and same for channel 5 all other channels are fine. Also the apps are showing live content fine as well.
S.grattan
Re: Itv and channel 5 satellite signal down
@Steve+quinnell
No. It's not a regional issue or national issue. It will be down to your dish.
ITV1, 2 and Channel 5 are all working for me. Try restarting your box and if it still doesn't work you may have a dish alignment issue.
Avatar for Steve+quinnell
Level 2 icon
I have turned the mains off left it for a couple of minutes checked all wires and all fine but still no itv and channel 5 but I have the apps to watch live anyway its just a nuisance due to recording programmes.
A massive thankyou for replying to my question all the best 👍
S.grattan
@Steve+quinnell
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Level 2 icon
I've tried everything and still no itv1 and now channel 5 is not working plus itv 2
S.grattan
@Steve+quinnell
So have you contacted Sky to arrange an engineer to check / realign your satellite dish as advised already?
Level 2 icon
I've got to call them as I can't order an engineer to come out because the page is not responding and saying I've got a package on its way. I will call them later and thanks for responding
Have you had issues with itv channels?
S.grattan
@Steve+quinnell
