Discussion topic: It says my satellite signal has a problem
This message was authored by: Timw29
Re: It says my satellite signal has a problem
@Timw29 try following the link below
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
@Timw29
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. The link already provided may give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye and could only affect one or two channels). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
