Discussion topic: It’s saying on my tv q box. It looks like you do not have internet connection.
Message posted on 04 Oct 2023 11:45 AM
Have switched off and tried reconnecting but nothing
Message posted on 04 Oct 2023 12:08 PM
Re: It’s saying on my tv q box. It looks like you do not have internet connection.
Hi @Yvi
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
