This discussion topic has been answered Discussion topic: It’s happening again -mini boxes not working but main box fine
Message posted on 16 Jan 2026 08:15 PM
Same thing happening again as last weekend, with all 4 mini boxes in my house not working this evening, but the main Sky Q box is fine. Have reset all boxes including main but all mini boxes giving the no satellite signal message. Is there another national outage?
Message posted on 17 Jan 2026 12:03 PM
@oldfella - the reset worked. Thanks.
Message posted on 16 Jan 2026 08:17 PM
Re: It’s happening again -mini boxes not working but main box fine
No outage at the moment @WLA
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
Message posted on 16 Jan 2026 08:42 PM
Thanks for the advice, unfortunately went through the process and getting the same no satellite signal message.
Message posted on 16 Jan 2026 08:50 PM
Update - looks like a hard disk problem. Recordings not showing on main box.
Message posted on 16 Jan 2026 09:55 PM
Hi @WLA
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
