Discussion topic: It keeps asking for my pin on a lot of programmes, but i switched off the pin on settings?
Message posted on 10 Mar 2024 01:54 PM
I've switched off the pin on all 4 options under parental settings & I still get asked for my pin on a lot of programmes - what else can I do as I don't want to keep entering a pin for tv shows/films? Thanks
Message posted on 10 Mar 2024 01:56 PM
Re: It keeps asking for my pin on a lot of programmes, but i switched off the pin on settings?
In some instances and times of day it's mandatory. See this previous thread.
Message posted on 10 Mar 2024 05:39 PM
@JuMcCloud1 wrote:I've switched off the pin on all 4 options under parental settings & I still get asked for my pin on a lot of programmes - what else can I do as I don't want to keep entering a pin for tv shows/films? Thanks
Change your PIN to something simple like '1111' - then it's VERY little hassle
Message posted on 10 Mar 2024 06:44 PM - last edited: 10 Mar 2024 08:22 PM
For a channel carrying post watershed content before 21:00 (Sky Atlantic and several Cinema channels being the main ones) the Mandatory Daytime Protection setting is not negotiable: it's having MDP which permits broadcast without incurring a massive Ofcom fine in the first place.
Message posted on 10 Mar 2024 10:08 PM
Yeah it's Offcom ruling, can't do anything about it.
My set up;
Sky Q - full package with 2TB HDR box & 4 mini boxes, all hardwired by ethernet.
Sky Superfast Broadband.
Panasonic 50" 4K TV.
Panasonic 4k Bluray Player.
Sonos 5.1 Surround Sound System.
Message posted on 11 Mar 2024 11:04 AM
Strictly speaking it's Ofcom enforcing the Broadcasting Code, which is based on parliamentary legislation. 'Taste and Decency' and 'Protection of Children' have been matters of concern for legislators since media was invented.
Message posted on 03 Apr 2025 03:22 PM
why is there an option to switch it off then ?
Message posted on 03 Apr 2025 03:27 PM - last edited: 03 Apr 2025 03:27 PM
@maelstromv wrote:why is there an option to switch it off then ?
Hi @maelstromv I would switch them on so you can see the difference.
Message posted on 03 Apr 2025 03:47 PM
Perfect!!! make it even more annoying, so if you live alone with no children your still forced to put up with it , technology is wonderful
Message posted on 03 Apr 2025 03:50 PM
Get your MP on the case to change legislation.
Message posted on 03 Apr 2025 03:51 PM
@maelstromv wrote:Perfect!!! make it even more annoying, so if you live alone with no children your still forced to put up with it , technology is wonderful
Not a technology issue, it's a UK law issue
Hi @maelstromv I use 0000. If you are looking to change it, I recommend lobbying your MP.
Message posted on 03 Apr 2025 03:59 PM
@MightyQuinn wrote:Hi @maelstromv I use 0000. If you are looking to change it, I recommend lobbying your MP.
Mine's slightly more complicated than that: 1111 😉
Message posted on 03 Apr 2025 07:15 PM - last edited: 03 Apr 2025 07:21 PM
Yes, because during the moral panic and tabloid* frenzy surrounding the arrival of 'foreign owned' satellite television, the fear was that children visiting a Sky household might be exposed to corrupting influences beamed from space.
These days we let the internet take care of corruption at home instead, but somehow this wasn't such a concern in the late 1980s....
* The ones not owned by a certain Australian, anyway ; )
Message posted on 03 May 2025 05:21 PM
Press Home on Sky control. Go to settings. Parental Control, click, enter your pin and turn off everything. This way you won't br asked for a pin when you go to certain channels
