Discussion topic: Issues with picture. I think related to dish
This message was authored by Joannie1 This message was authored by: Joannie1
Problem with dish I think. Picture keeps going off. Message says problem with satellite
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Issues with picture. I think related to dish
@Joannie1
If you have Sky Q and are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s almost certainly a dish alignment issue so check the troubleshooting in this link
It’s worth remembering that a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
@Joannie1  Your post has been moved from the broadband forum as this isn't broadband issue.
Which SKy TV box do you have, Sky+HD or Sky Q?
