Discussion topic: Issue with sky q box going blank and issue with apps on both sky q and mini box
This message was authored by: Jclayton
I kept getting an issue when my sky q box just won't work the screen goes black and I can't press anything or do anything on my sky q box.
I also have an issue with the apps on both my sky q box and mini box they either won't load at all or just constantly buffer. I've refreshed my apps but it's still not working correctly.
Also my downloads take forever it took 5 hours to download a 30 minute episode.
Re: Issue with sky q box going blank and issue with apps on both sky q and mini box
Hi @Jclayton
