2
This discussion topic has been answered Discussion topic: Is there any way to disable the 'remote finder' feature on SkyQ.
This message was authored by: hanpan87
My little one has discovered that long pressing the Q button makes the remote beep.  Whilst this is an extremely handy feature, I was wondering if it's possible to disable it just for my sanity?
This message was authored by: MightyQuinn Answer
Re: Is there any way to disable the 'remote finder' feature on SkyQ.
Hi @hanpan87   You could remove Bluetooth from your remote by holding down 4 & 6 until the remote flashes. However you would then lose the Voice Search facility and the remote has to "see" the box. Perhaps as a temporary measure until his behaviour changes.
Avatar for hanpan87
Level 2 icon
Thank you that sounds like a good plan!
