Discussion topic: Is there a way to stop kids subscribing to stuff
This message was authored by: Lennonhorbs
Message posted on 29 May 2024 01:12 PM
Is there a way to put a code or something on my sky box to stop my kids subscribing to stuff
Find out more
Message posted on 29 May 2024 01:19 PM - last edited: 29 May 2024 01:20 PM
Re: Is there a way to stop kids subscribing to stuff
If you mean purchasing content on Sky Q, that's here:
You can set up your Sky box to require a PIN when making a Sky Store or Box Office rental over a certain limit. Remember, you'll always need your PIN to make a Buy & Keep purchase.
To turn this setting on:
- Press services on your Sky remote, select Parental Control and PIN and enter your 4-digit PIN at the prompt.
- Highlight PIN Required for Purchases, then set the puchase limit before your PIN is required. This could be Always, Over £1.00, Over £2.00, Over £3.00, Over £4.00, Over £5.00, Over £10.00 or Over £20.00 (or the euro equivalent).
- If you don't require a PIN, switch it off by selecting NO.
- Press green to save the setting, then sky to return to your viewing.
If you want to PIN-restrict interactive purchases:
- Highlight PIN Required for Interactive Purchases and change the setting to YES or NO to turn it on or off.
