Discussion topic: Is it possible to pair my skyQ to my sound bar
This message was authored by: Michael+France
Is it possible to pair my skyQ remote to a soundbar
This message was authored by: bob1234
Re: Is it possible to pair my skyQ to my sound bar
@Michael+FrancePossibly if it is on the  list, however if your TV has HDMI arc then if your soundbar has an HDMI input connecting the two will allow the Q controller to control the volume of the soundbar via your TV.
It may be possible @Michael+France
Depends if your Brand and model is in the Sky Database.
Bear in mind that pairing the remote to a Soundbar will only give you control of Volume and mute and this is instead of TV volume control.
'On/Off and input select will not operate the Soundbar as this is always reserved for paired TV.
If you want to try pairing
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.   You pair to TV first and then you are asked if you want to pair to Soundbar/Amp
Avatar for Michael+France
Thanks oldfella....something that worked ....hope your well....I have MS  so this really makes it easy without another remote  👍🙂
