19
This discussion topic has been answered Discussion topic: Is it possible to disable the TV Guide when switching on my Sky box?
This message was authored by: Walt+Jabsco
When I switch on my Sky box, the TV Guide automatically appears
Is there an option for the TV Guide not to automatically be displayed every time I turn on my Sky box?
Thank you in advance
Re: Is it possible to disable the TV Guide when switching on my Sky box?
Hi @Walt+Jabsco
When you switch on the Q box you should get the Home page and this cannot be changed.
Do you have Sky Q?
Hi @Walt+Jabsco
Do you have Sky Q?
This message was authored by: NickNewark
That's a No.
Avatar for Walt+Jabsco
Yes I have Sky Q. I have to turn off the TV Guide whenever I switch it on, as I prefer to just select the channel I need manually.
Hi @Walt+Jabsco
Suggest you take another look when you switch the box on.
It is the Home page that you get and not the TV Guide.
Yes - either way - it's the home page/TV guide that I don't want displayed as it means I have to turn it off every time
@Walt+Jabsco
It's one press of the dismiss button.
Unfortunately @Walt+Jabsco SKY have a different view.
It is a deliberate decision that we must always have the Home page where they can push any content they wish
As per the first reply, it can't be changed.
Hi @Walt+Jabsco
Best thing to do when you press Standby to turn the Q box on just follow that by pressing the Dismiss button  (left of Home button).
When the Q box comes on it will be on the last channel watched and not the Home Screen
Yes, obviously. Which is why I asked the question about how I can avoid doing that.
@Walt+Jabsco
It's one button press so not time consuming.
Hi @Walt+Jabsco   You can't. That is unless you apply a 3rd party solution like a harmony hub. When I switch on Sky Q using a Harmony Elite it always goes to the last channel viewed because I have programmed the Dismiss button into the start sequence.
I asked the question - on a forum to help Sky users - as I don't want to have to press another button every time I turn on my Sky box
(removed)
Moderator note: Can we please be nice to each other.
@Walt+Jabsco
Although the replies aren't what you wanted to hear I'm afraid the answers remain the same.
