Discussion topic: Is it possible to disable parental control. I’m 70 and my wife is 60 and it’s stupid inputting a PIN
This message was authored by: Tonym123
We want to disable parental controls before the watershed as it's annoying having to input a PIN every time we want to watch a program.
Re: Is it possible to disable parental control. I’m 70 and my wife is 60 and it’s stupid inputting a
hi @Tonym123
Unfortnately not - When SKY Atlantic & other channels show certain material before the relevant 'watershed' it will always be present & you cannot turn it off
https://helpforum.sky.com/t5/Sky-TV/Is-there-any-way-I-can-turn-this-damn-parental-control-off/ba-p/...
Do, however,  check that all the relevant options in Parental Controls are appropriately set but as I say you may need it for some
Our advice is to set the PIN to something like 1111 to help enter it when needed
This message was authored by: daveNOS
@Tonym123 It's not possible to remove the PIN requirement for content before the watershed, that is down to OfCom rules.
