The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
16 Jun 2021 07:17 AM
Hello,
I have a Sky q 2tb with an additional mini q box. Today I upgraded to Sky Signature from the old entertainment.
Just realized that the Sky Q multiscreen pack gets replaced by Multiscreen.
Are they the same or more specifically would I still be able to use my mini q box?
Thanks in advance
16 Jun 2021 07:24 AM - last edited: 16 Jun 2021 07:27 AM
Posted by a Superuser, not a Sky employee. Find out morehi @dimuth,
Yes you can still use your mini box.
The key difference is that with the Multiscreen pack (which went with the entertainment base package), in addition to allowing mini box & SKY Go usage, it also enabled 4K on suitable boxes.
If you used this for 4K make sure that you now have the UHD Pack which is needed for 4K with Signature
When I migrated to Signature it was automatically switched correctly so I have the UHD pack as well as the plain 'Multiscreen' add on now
16 Jun 2021 07:20 AM
Posted by a Superuser, not a Sky employee. Find out more@dimuthSky love to change things to confuse, multiscreen, mutiroom etc etc all allow the mini box (any number) to work
