Discussion topic: Internet won’t connect to box but internet is working
Message posted on 24 Aug 2024 10:02 PM
Internet won't connect to internet
Message posted on 24 Aug 2024 10:03 PM
Re: Internet won’t connect to box but internet is working
Apologies box won't connect
Message posted on 24 Aug 2024 10:04 PM
Hi @Sarah296
Message posted on 24 Aug 2024 10:06 PM
Thank you for your reply
I've done all of that it's not worked
Message posted on 24 Aug 2024 10:15 PM
It's saying updating software step1 if 2
does this take hours?
Message posted on 24 Aug 2024 10:18 PM
Hi @Sarah296
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Message posted on 24 Aug 2024 10:21 PM
Message posted on 24 Aug 2024 10:22 PM
Thank you
