Discussion topic: Internet fine in house, Sky box disagrees
Message posted on 06 May 2025 02:38 AM
I don't use a Sky Router, their fibre hasn't reached our village yet. So I am using a Voneus provider and their Zyxel box.
i am writing this with internet access wich is fine throughout the house, but under settings section of my SkyQ box says that my network is not connected. Every 5 mins or so, it connects and I get a pair of ticks for about a minute and then it drops.
i have tried wired connection to my router and Wi-Fi but the symptoms are still the same.
Did advanced and put my SkyQ box IP address to no avail.
getting a bit grumpy now as I have no access to Catch up, On Demand, Best of, Apps, etc
look forward to some advice
TIA
Gary
Message posted on 06 May 2025 07:41 AM
Re: Internet fine in house, Sky box disagrees
Have you worked through the steps here? https://www.sky.com/help/articles/sky-q-permanent-connectivity-problems
If so, have you ensured the Q box is up to date? https://www.sky.com/help/articles/updating-sky-box-software-sky-q
If so, you might want to try a factory reset. Sky will make you do most of this stuff anyway before sending a replacement or organising an engineer.
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | SONOS Beam 2 | Apple TV 4K | EE Full Works FTTC
Message posted on 06 May 2025 07:03 PM
I think there is a bug that has been introduced. I'm having the same issue
Message posted on 06 May 2025 11:03 PM
Justwine,
Sorry to hear you are having similar issues.
It feels better to find that I am not on my own.
G
Message posted on 10 May 2025 01:56 PM
Stereohaven
Thanks for your email. It has taken me a while and unfortunately none of the soluitions appear to work.
I have even run a cable direct from router to the box, still to no avail
Cheers
Gary
Message posted on 10 May 2025 06:34 PM
Worth a shot, might be time for an engineer then.
I would contact Sky and keep an eye on this thread just in case anyone else has a suggestion.
