Discussion topic: Intermittent picture pixelating only on BBC1 South since the changes a few months ago.
Message posted on 11 Apr 2023 11:26 AM
Picture pixelating only on BBC1 South. Channel selections were changes by Sky a few months ago previously all was fine.
Have cleared line of dish and checked for damage and inside connections all looks fine. Am currently using BBCi player to watch BBC1.
All other channels are fine
Message posted on 11 Apr 2023 12:15 PM - last edited: 11 Apr 2023 12:19 PM
Re: Intermittent picture pixelating only on BBC1 South since the changes a few months ago.
BBC One South HD is on the same frequency as:
505 CNBC HD
601 Cartoon Network HD
603 Boomerang HD
When you have problems with BBC One are those channels affected too?
Message posted on 11 Apr 2023 03:09 PM
It is not a signal issue - it is a fault with the transmission.
I've seen it too on BBC1 South.
What I see is not like a signal issue where you get a row of pixels or even a whole screen. I see a block of pink pixels appear somewhere near the centre of the screen only.
We had it before a BBC1 found a fault.
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
Message posted on 11 Apr 2023 03:42 PM - last edited: 11 Apr 2023 03:47 PM
It would be useful to know if the OP has a problem with the channels mentioned just to rule out a signal issue that might be separate to the issue you describe. The problem must be quite severe if they've resorted to watching BBC One via iPlayer and it's surprising there aren't more complaints if this is the case for everyone watching BBC One South.
Message posted on 11 Apr 2023 03:55 PM - last edited: 11 Apr 2023 03:56 PM
Only 2-3 people reported it last time - but BBC found it.
It only lasts a fraction of a second and then goes for ages before occuring again.
It is just like 3 little pink squares popping up.
You can sit and watch the channels for hours without it happening.
It was confirmed last time as a couple of VirginMedia customers reported it too.
Might be a different issue - but looks exactly the same as last time.
@xenon81 wrote:It would be useful to know if the OP has a problem with the channels mentioned just to rule out a signal issue that might be separate to the issue you describe. The problem must be quite severe if they've resorted to watching BBC One via iPlayer and it's surprising there aren't more complaints if this is the case for everyone watching BBC One South.
Message posted on 11 Apr 2023 08:08 PM
Also has the same problem when 505 is selected.
I do not have the other 2 channels enabled so cannot try those.
Message posted on 12 Apr 2023 11:26 AM
I too have the same problem with BBC1 South only. I live on a BBC tri-region reception area and my postcode is literally within 300mtrs of 3 different counties. Equi distant from Reading & Basingstoke and most other programmes feed from London region.
Thankfully on the rare occasions I actually feel the need to watch BBC1 I also have Freeview with the facility to record the channel problem free.
I have given up entirely with BBC1 South on Sky Q. The inability to switch regions manually on Sky Q is, in my opinion, a retrograde step. TBH I really don't have the time or willpower to try to contact Sky for a script reading remedy.
Message posted on 12 Apr 2023 04:41 PM
Hi all,
Thank you for bringing to my attention. I have passed this onto our support teams to investigate this and will update this thread once I have more information.
Thank you.
Community Manager
Message posted on 20 Apr 2023 08:34 AM
Hi all,
Our support teams are unable to replicate this issue however if you are continuing to see this issue please let me know and I will pass this on.
Thank you.
Community Manager
Message posted on 20 Apr 2023 08:48 AM
I would suggest Gillian19 needs an engineer visit as they've confirmed the problem is also affecting CNBC HD (505) on the same transponder so it seems like a signal fault.
Message posted on 20 Apr 2023 09:49 AM - last edited: 20 Apr 2023 09:53 AM
I'm getting a thick row of pixels on BBC South East since the switch.
Could be just coincidence I guess but I'm somewhat suspicious..
I'm going to be moving house in the near future anyway so not really bothered by it..
Message posted on 20 Apr 2023 04:10 PM
Hello all and thanks for all your efforts to help. However problem is still the same.
Regards
Dave
Message posted on 20 Apr 2023 04:11 PM
Hi there,
If you're still having the issue it may be worth calling Sky to arrange a visit / go through some furthur troubleshooting
My views are my own and I will assist where possible.
Sky Q 2TB UHD, 2X Mini Box, Sky BB UF1, Booster 4
I am just a customer, If I've got something wrong feel free to tell me, If I've something right mark it as an answer
Message posted on 01 May 2023 05:41 PM
Sky engineer visited. Checked dish signal, Changed HDMI cable and HDMI port and fitted new dish cable to Q box connectors. All checked good by engineer.
Problem still the same. 😕
Suggested as not a sky problem.
Gillian
Message posted on 01 May 2023 06:20 PM
I'm not in the BBC South region but haven't noticed any problems on the other channels on that transponder. Are you still having problems with CNBC too? That's working fine for me so it isn't a national problem.
