Discussion topic: Intermittent connectivity with signal to Sky Q. Making watching anything app related tiresome.
This message was authored by: C7020
Everytime we switch the TV on a message about no internet signal with regards to using apps.  Two other TVs on the network won't get a signal at all without rebooting the router and booster which is monumentaly tiresome on a daily basis - sometimes more than once a day.  Either the router isn't powerful enough or the SkyQ box needs a better reciever.  Failing that it could well be the exterior antique cable leading to the house which doesn't look in good shape.  Our neighbours don't have a problem with reception.
Re: Intermittent connectivity with signal to Sky Q. Making watching anything app related tiresome.
Hi @C7020
Who is your Broadband supplier and what WiFi booster are you using?
Also please confirm the following
  • What is the booster connected to?
  • Where is the booster located?
Avatar for C7020
Both are sky branded. Booster located in upstairs hall to avoid a solid wall barrier.
