9
This discussion topic has been answered Discussion topic: Interference on premier sports 1
This message was authored by: KirstyR
I am constantly getting interference/pixelated screen or the blue problem with the signal on premier sports 1. Is anyone else having the same problem? It's the only channel it's happening with.
This message was authored by: ozsat Answer
Re: Interference on premier sports 1
No issues here.
Have a look at GB News (on 512) and CNN (on 506) - they are likely to have same issue.
You most likely have a dish alignment issue which will need a call to Sky for a resolution.
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
No issues here.
This message was authored by: kimeliz
Hi! Did you manage to fix this?
If you have the same issue, the post marked as Answer also applies to you.
I can't see anything from the original poster to say if that was the issue though?
Avatar for KirstyR
It appears that is the issue however I haven't yet had it fixed as I haven't had time to contact CS and arrange a visit.
Thanks Kirsty , I went online and an engineer can come out tomorrow so hopefully they can fix it.
This message was authored by: LucyT2
Hi, we are having this same issue. Was the sky engineer able to fix it for you? Interestingly Premier Sports 2 works fine
Avatar for KirstyR
Yes the dish was slightly out of alignment but it was also quite an old dish so they replaced it at the same time.
It's on a different frequency (unlike the other two channels mentioned in the Answer post) so dish alignment has a subtly different effect. This is usually how minor dish problems manifest with just a handful of channels on the same frquency being affected.
You can check which channels are multiplexed on the same frequency here
https://www.lyngsat.com/Astra-2E.html
edit: although weirdly some of the Sky stuff there doesn't specify the channels any more. Hmmmm. I found another site which says Sports 1 is on 11671H and Sports 2 is on 12188H. The two other channels it says are currently also on 11671 are CNN HD and Loveworld TV HD.
