2
This discussion topic has been answered Discussion topic: Info banner appeared over last 5 mins of show
This message was authored by: Cyprusgirl
As in summary- downloaded Das Boot. Episode 1 end ruined by not being able to see subtitles due to banner with info re that episode, episode 2 and due to start....and episode 3 etc. Couldn't get rid of it. Never had this problem on any programme before.
This message was authored by: Laing1 Answer
Re: Info banner appeared over last 5 mins of show
@Cyprusgirl if you press the dismiss button on your remore  the one to the left of the home button that should remove the banner.
Alternatively you can go in to settings and change the settings not to automatically play the next episode
Avatar for Cyprusgirl
Cheers ! Worked  ta very much.
