Discussion topic: In need of a new sky box
Message posted on 03 May 2025 09:58 PM
Hi,
My son walked behind the tv and knocked the wire. I heard a snapping noise and now doesn't work says I have signal in settings but on tv guide it says no signal.
Message posted on 03 May 2025 10:19 PM - last edited: 03 May 2025 10:22 PM
Re: In need of a new sky box
@Daynalevy wrote:
Hi,
Best to check the two F connectors on the dish cables at the back of the Q box @Daynalevy .
With the box switched off, remove the two connectors and carefully check the the central copper conductor is not bent or broken and protrudes approximately 2 to 3 mm.
