Discussion topic: In a vshort power cut on Sunday the new Sky Q mini box went off and will not come back on!
Message posted on 16 Nov 2023 12:39 PM
9/11 we had Sky Q box installed in the living room and a Sky Q Mini in the kitchen, Sunday we had a vshort power cut which resulted in the Sky Q Mini not working. Have tried following the instructions of putting the plug off, resetting etc, nothing is happening. It goes as far as 1 to 4 please press the • button, and doesn't respond to the remote there on!
The Sky box in the living room came back on straight away and hasn't been affected.
Message posted on 16 Nov 2023 12:59 PM
Re: In a vshort power cut on Sunday the new Sky Q mini box went off and will not come back on!
Hi @MidWales
Reboot the mini as above.
If you still cannot get past the 1 of 4 step try resetting the mini remote to infrared mode by pressing and holding 7 & 9 on the remote until it's led flashes 4 times.
Then try the 1 &4 again and see if the box respond to the remote. (Make sure that you are pointing the remote at the mini as infrared mode needs line of sight).
Also bear in mind that when it tells you to press the WPS it means on the main Q box).
If this gets your mini working you will need to re pair the mini remote for Bluetooth.
Make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Message posted on 16 Nov 2023 02:51 PM
Wel I'm not sure what and how it happened but I followed you instructions to the letter and we know seem to have a working Sky Q Mini in the kitchen! Many thanks, top job sir, Sky should pay you!👌🏽
