Discussion topic: In Settings says problem with network connections at the side is an x
This message was authored by: Linda553
I cannot get into my appts or connect or us my voice remote control. On the Home setting the  information says No programmes are currently being broadcast on this channel. I can get channels on TV guide and record as usual. In my are this weekend others have had problems with sky and internet down. My internet has now been restored but i have still the above problems.
Re: In Settings says problem with network connections at the side is an x
Hi @Linda553
Avatar for Linda553
Thankyou. I followed the information but still have a problem. Not able to access appts or us remote control
Exactly what happened when you carried out the Network reset on the main Q box @Linda553 ?
Avatar for Linda553
while i accessed settings, An action of spinning symbol and writing saying to press and hold button on your  broadband router, which I did, the green light flashes but still no connection.
Avatar for Linda553
After nothing happened green light on router went out and then back to the information on screen saying, Unsuccessful connection Please try again, or you may need to connect a Sky Q Booster.
hi @Linda553
If you are trying to WPS then I assume you are on Sky Broadband.
If so then the WPS light on the router will flash Amber not Green.
ie
  1. Hold the WPS button on your booster for 3 seconds until it flashes amber. Then hold the WPS button on the front of your hub for 3 seconds until it flashes amber - You'll need to do it within 2 minutes.
  2. After a few minutes, the connected light will turn green. You're all set up.
If you are on Sky Broadband then WPS button on router is shown below.
