Discussion topic: Im having issues with the menu page disappearing and wifi conection
This message was authored by: Don50
My menu disappears and doesn't return unless I knock the power off and reboot it.
Also the wifi conection is so bad I have it running through a cable.
Re: Im having issues with the menu page disappearing and wifi conection
Hi @Don50 .
Two completely different issues I would think.
Regarding Q box function
Regarding WiFi  then this is subject to multiple factors but mainly distance and blocking obstruction.
If connection by Ethernet is practical then it's the best option.
If you have no mini boxes and are on 3rd party broadband then it's best to turn off the Q box WiFi when using Ethernet.
On the main Q box first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router (or Sky router if on Sky Broadband). Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
If you have no minis then as soon as it connects go immediately into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
