Discussion topic: Ideas about connecting minibox from distance
Message posted on 08 Jun 2023 09:58 AM
My son has moved into an annex to our house and wants to run a minibox from the main Sky Q box in the main building. It is about 30/40 meters away. Sky advised us to connect through our WiFi. It did connect briefly but then dropped out. Any ideas about making the connection more stable. Our WiFi is good and solid in the annex.
Many thanks
Message posted on 08 Jun 2023 10:49 AM
Re: Ideas about connecting minibox from distance
Many thanks
Always best to use Ethernet wherever possible @Cedar75
Message posted on 08 Jun 2023 11:12 AM
@Cedar75Unless Sky is your broadband supplier it does not use your home WiFi to link boxes.
It generates its own WiFi link on 5Ghz which is probably not a strong enough to reach the mini box.
If the annex is on the same mains circuit as the main Q box you could use a powerline LAN extender and then connect both the main and mini box by Ethernet to the two powerline units.
