Discussion topic: ITVX ON MAIN SKY BOX BUT NOT ON DIGIBOX, WHY?
Message posted on 31 Mar 2023 06:59 PM
Why can't I find ITVX on my apps on my sky digibox?
Message posted on 31 Mar 2023 07:36 PM
Re: ITVX ON MAIN SKY BOX BUT NOT ON DIGIBOX, WHY?
@SandraJT Do you mean the Sky Q mini box?
Message posted on 31 Mar 2023 08:12 PM
apologies, yes I do
Message posted on 01 Apr 2023 03:42 PM
@SandraJT wrote:
apologies, yes I do
@SandraJT if it is not showing under apps on the menu you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 01 Apr 2023 05:31 PM
All caps subjects sound very angry 😞
What version of firmware is on the mini?
Have you tried the "ITVX" using voice control on it?
