Discussion topic: ITV1 HD states no satellite signal being recieved
Message posted on 05 Oct 2023 03:32 PM
When selecting channel 103 it states there is an issue with the satellite signal. All other channels are working fine, the signal strength is 60 and the quality is 90. I have attempted to manually tune ITV1 HD and this works fine, so unsure why channel 103 will not show the programs.
I have carried out a factory reset and the issue remains, any ideas?
Message posted on 05 Oct 2023 03:38 PM
Re: ITV1 HD states no satellite signal being recieved
@DM_1077
If it still displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. Just to make you aware, if you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
Message posted on 05 Oct 2023 03:44 PM
Cheers @Daniel0210, i went through the trouble shhoting guide before to no avail, i will look to get an engineer out. Thanks
