Discussion topic: I’ve removed all the leads to my tv and boxes and must have made an error reconnecting because my mu
Message posted on 13 Jun 2025 09:55 AM
Please can you advise on how to reconnect correctly
Message posted on 13 Jun 2025 10:23 AM
Re: I’ve removed all the leads to my tv and boxes and must have made an error reconnecting because m
hi @Alb3rt
It is difficult to tell which connection(s) you are having problems with, as your title seems to have been cut off.
Please can you give more detail of what you are seeing (or not seeing) inclding any messages & anything else that will help us to help you.
Can you also let us know if you have your own dish or have a feed from a communal system
Message posted on 13 Jun 2025 03:56 PM
My kitchen tv tells me I'm not connected to Q box. Also some channels on main tv do not come on and j cannot pause the channel I am watching.
Message posted on 13 Jun 2025 04:00 PM
Hi @Alb3rt
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
