Discussion topic: I’ve joint broadband but it’s not picking up my sky tv and Netflix
This message was authored by: Frosty+75
My sky tv for over 2 weeks has not been working it is saying I do not have internet connection
Re: I’ve joint broadband but it’s not picking up my sky tv and Netflix
What is Joint Broadband @Frosty+75
Have you tried a Network reset on your Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Avatar for Frosty+75
I have done all what you have suggested previously but it still is not working
Hi @Frosty+75
You haven't said what you mean by Joint Broadband.
I have just joint sky for broadband and my sky and Netflix are saying no internet connection
Ahhh so you have just Joined Sky then @Frosty+75
First reboot your Sky Router by disconnecting the power lead for 30 seconds and then reconnecting.
Wait until the Router is completely back up and running and then Reboot your Q box.
If you still are not connected to the internet try the Network reset again.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your Sky router.
You will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
